Heater blowing cold air (Digital Climate Control)
Old Oct 19, 2009 | 07:36 PM
my87_5spgta's Avatar
I have 87 trans am with a dig dash digital climate control.I was wondering why i had no heat to find out that whoever had the car before me had the heater hoses bypass the hearter core.I just put a New heater core in and still no heat? All the climate switchs seem to work? Anyone know how to check this climate control or what to check next?
Old Oct 19, 2009 | 09:51 PM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
Re: Heater blowing cold air (Digital Climate Control)
If you have hot water going through the heater core and you still have no heat, it is probably a problem with the blend air door. I'm not familiar with the digital set-up, but on vacuum ones, the control switch/lever determines where the blend air doors will go/what they will actuate between upper/lower ducts and hot or cold ducts. So for whatever reason, it sounds like the blend air doors are not getting the signal to go to heater core for heat when you select it on the control. Fuses maybe? Check the connections behind the controller if it is all electric and not vacuum fed? If it is electric and not vacuum servo operated, motors for the blend air doors maybe...check them? Like I said, not real familiar with the digital set-up, but it should be pretty easy to determine if you have vacuum feeds or not. If it has vacuum feeds, check the vacuum lines/hoses for breaks...possibly the vacuum servos/diaphragms could be bad.
Old Oct 20, 2009 | 11:31 AM
Thanks i will ck it out!!
Old Oct 20, 2009 | 11:59 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
No ( or Low temp ) Thermostat ?? Is the engine reaching operating temp ??
Old Nov 10, 2009 | 11:05 AM
ikeepitreelz's Avatar
Car: 1988 gta-
Engine: 383 tpi
Transmission: 700 r-4
Hmmm.. I have the same car with the push style button climate control, If you stand in front of the engine bay on the left side coming out of the firewall there should be a small black hard plastic hose coming out and it should be plugged in to a valve,more or less located about 12 inches or so behind the a/c compressor, the valve has a black water house coming into it..i had the same problem. You can also check under the passengers side foot well and look up to see if the door is stuck. P.M me if you can't find the hose i can take a pic of it and you can go by that. Good luck!!!
Brinkkl2000
Aug 4, 2018 08:29 AM
stalkier
Dec 6, 2015 11:25 PM
kyle5647
Aug 15, 2015 11:56 PM
jackhammer
Aug 15, 2015 10:04 PM
tnrednneck
Aug 13, 2015 08:57 AM
