brake lights stopped working
Old Oct 21, 2009 | 10:55 AM
I_R_O_C_Z_2_8's Avatar
Car: 1991 Trans Am GTA
Engine: 350 tpi
Hi i just noticed my brake lights stopped working everything works accept the brake lights i checked the bulbs and they are fine any help would be great thanks
Old Oct 21, 2009 | 01:18 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Take A Brake
Check the STOP HAZ fuse.
If it’s good use a meter to check the brake light switch.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fog lights are not driving lights. They look doofy. Turn em off slow pokes.
How bout those nervous nellies too scared to drive without headlights on in the daytime or if there is a little rain!
Old Oct 21, 2009 | 02:19 PM
Engine: 350 tpi
Re: brake lights stopped working
And where is the brake light switch located at exactly?
Old Oct 21, 2009 | 03:11 PM
NINÅ's Avatar
Transmission: 765R4
Brake Light, Don’t Slam Them
The brake light switch is behind the brake pedal in the foot well.
If you have cruise control it’s the one WITHOUT the hose.
Happy Racing!
Old Oct 21, 2009 | 05:52 PM
Engine: 350 tpi
And what exactly em i looking for something burned or power?
Old Oct 28, 2009 | 11:30 PM
poppa843's Avatar
Turn on your hazard lights. If they work then the fuse is is still good for your brake lights. If the bulbs are good. Then remove the bulb and check the contact in the socket for voltage with the brake depressed. The brake light switch is white and has a threaded portion that mounts to a plate on the front side the pedal. Check for voltage at the light blue wire coming from the switch. Just fixed my lights today. It was a bad switch. Oh and if ur switch is bad be careful when removing it not to damage the little gold piece that holds the switch to the plate. If u break it like I did uses two nuts to hold the switch in place. One on each side
Old Nov 2, 2009 | 02:34 AM
crug75hid's Avatar
thats often with motorcycles. but if a car experience so then you can try the same way out. replace the floor wiring. that usually causes so
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
Wade787b
Sep 29, 2015 01:15 PM
Omega
Aug 10, 2015 12:46 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
