89 camaro Help!!!!!
Old Oct 24, 2009 | 11:23 AM
ryan_3's Avatar
Car: 89 camaro rs
Transmission: automatic
89 camaro Help!!!!!
This is my fist car its a 89 Camro rs and it has its problems. well the other day i went to get gas and it was about 8:45 so I had my headlights on, and they were shinning bright and working. So I pulled in got my gas came back out started the car, and when I went to turn the headlights on they wouldnt come on. All the lights work in the car and out except for the headlights and the right side running light(if you were sitting in the car its on the right)the wierd thing is it dosnt work but wen I turn the right turning signle on it works fine. So I checked to see if the terminal had a bad connection they were tight so I took thenm off and put them back on and tightened them. Then I checked every fuse and there all good. What should I do next? also if I need to check the ground wires to see if there not rusted or broken where are they located?
Old Oct 24, 2009 | 10:08 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 89 camaro Help!!!!!
Headlights I don't know - did you check the fuse?
Park light just needs replaced - buy a new bulb.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
