MANUAL COLLING FAN =c
Old Oct 28, 2009 | 09:58 PM
psp963's Avatar
Car: 1989 camaro rs
SO THE 89 CAMARO I BOUGHT FEW MONTHS AGO HAS MANUAL COOLING FAN WITH A SWITCH UNDER BY THE FUSE BOX....THE WIRES 2 THE SWITCH GET vvveeerry HOT...WHY IS THAT ITS COPPER WIRE...
Old Oct 28, 2009 | 10:40 PM
y84pauloflondon's Avatar
Car: 87 T-Top GTA
Re: MANUAL COLLING FAN =c
Could be wrong gauge of wire, could be unfused wires, cheap On/Off switch, or crappy work!(bubble gum and shoelaces wrapped in duct tape).
Old Oct 28, 2009 | 10:47 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
probably because they connected those wires straight
to the fan motor instead of using a relay like the
original fan circuit,probably too-thin wiring too,18 GA
or so,if it's the original fan that will draw around 12amp
at full speed,over 30a for a couple seconds after it is
first switched on until it's up to speed. fan should be
reconnected using a good quality relay and proper
wiring,pretty easy to hook up an add-on thermostat
control if you do not want to repair and reconnect the
original fan circuit.
Old Oct 28, 2009 | 11:00 PM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
Might want to get that fixed because a hot wire will melt and whatever else is around it. Becareful inspect your other wires to make sure they are not burned.
Old Oct 28, 2009 | 11:13 PM
Car: 87 T-Top GTA
Perfect Post! A++
Old Oct 28, 2009 | 11:24 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
thanks,problems with the fan circuit seems to be
almost chronic with the LO3 cars for some reason
Old Oct 28, 2009 | 11:31 PM
Car: 87 T-Top GTA
Its amazing how many car out there have manual switches because the PO didn't how to fix it, or they didn't want to spend time or money and fix it right!
junior419
Apr 7, 2025 11:35 AM
gta892000
Aug 11, 2019 11:16 AM
codeysabatini
Nov 10, 2015 04:07 PM
tommy z-28
Oct 6, 2015 10:58 PM
gta892000
Sep 16, 2015 12:37 AM
