Do I need a VSS sensor?
Old Oct 29, 2009 | 07:08 PM
consequence's Avatar
So I am continuing my rebuild on my camaro and I am wondering if I need the tranny VSS for the cruise. My control module has a red wire coming out of it but I have nothing to plug into it and I know it is for the VSS. I have an instrument panel from the car with the harness and it has the yellow box on the back of the speedo. Do I still require the other sensor to run it or am I missing a wire off my cluster for the module?
Any help is appreciated thx
Old Oct 29, 2009 | 08:40 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Do I need a VSS sensor?
Listing the make, model, and year of car is always helpful. 82-89 Camaros are cable driven and have the VSS on the rear of the cluster (you don't even require the ECM for the cruise if you ground the module). 90+ has the VSS on the tail shaft of the trans. Perhaps the following link will be useful:
https://www.thirdgen.org/forums/engi...-function.html
JamesC
Old Oct 29, 2009 | 08:49 PM
Oh sorry its an 83 camaro with cable speedo and the cruise off an 84. The cruise is the electronic type (no transducer).
Old Oct 29, 2009 | 11:05 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
'84 up cruise does need the VSS.
$750 L98
Feb 1, 2025 02:25 PM
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
