gas gauge problems
Old Nov 5, 2009 | 09:43 PM
dirtyd6669's Avatar
Car: 87 Trans Am
gas gauge problems
i think its electrical but dont know so sorry if its in the wrong place but would anyone be able to tell me why my gas gauge doesnt work it stays on full all the time and never moves any ideas would help THANK YOU
Old Nov 6, 2009 | 08:04 AM
CaliChevyLover's Avatar
Car: 1986 IROC-Z28
Re: gas gauge problems
i honestly would forget about it. use your trip odo, fill up ever 150-200 mi dependin on ur drivin style and rear gears
Old Nov 6, 2009 | 08:33 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Sounds like either a bad fuel pump sending unit in the tank, bad guage, or bad connection between the two. The only way to really test it out would be to drop the tank and play with the float level by hand while checking the readings on a multimeter. Not a fun task, been there before.
Old Nov 6, 2009 | 12:33 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
One easy thing to check is the tank ground which is under the driver's side rear seat bottom.
Old Nov 10, 2009 | 11:23 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Fuelish Thots
Here is my much easier way to find out if it’s a bad gage.
Test the fuel gage by disconnecting the sensor line and connect a 47Ω resistor from the point you removed the sensor line, and connect the other end of the resistor to ground.
Turn the key on RUN.
If the gage indicates approximately half full the gage is good.
Therefore the problem should be the sender.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fog lights are not driving lights. They look doofy. Turn em off slow pokes.
How bout those nervous nellies too scared to drive without headlights on in the daytime or if there is a little rain!
Old Nov 10, 2009 | 12:07 PM
Guest
Guest
Posts: n/a
Re: Fuelish Thots
Pull the gauge bezel and make sure its not pegged off the gauge, my temp gauge was pegged all the way off the gauge and I thought it was the sender so I put in a new 1 and nothing and when I put my leds for my gauges in I found the needle was stuck off the side so I bent the outer edge like a taco and now it works! ; )
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
BurlyChev
Aug 16, 2015 09:08 PM
