Left Turn Single light Front..really weird!
Old Nov 7, 2009 | 09:48 PM
F.L.A.G's Avatar
Car: 1982 Trans AM
Engine: 305 Single Carb
Transmission: Automatic
When I turn on my lights the left (orange) parking does turn on but is on really low. Even when I turn on the left turn signal it does not click on and off as it should. Sometimes it doesn't turn on at all and when it does it is very very low. I tried changed the bulb, makes no difference.
THanks for the reply's guys.
Old Nov 7, 2009 | 10:37 PM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
Re: Left Turn Single light Front..really weird!
That is really weird my guess would be a bad ground or short. but for just one to do that idk. I would check out your connections if dirty might do that. meaning on the bulb plug. Try keep it on the turn signal on and wiggle the bulb. Mine did that. Until it got brigther. it was just loose. Worn plug not holding the bulb was my problem. But worth a try to check it out.
Old Nov 8, 2009 | 05:32 PM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Been there. Bad ground. Dim bulb usually means the current is flowing through the bulb backwards. Check grounds on radiator support. Socket ground might be rusted out requiring a replacement socket pig tail from Rock Auto or elsewhere.
Ground a wire on the chassis and touch the other end to the metal collar of the bulb while its still in the socket and see if it works correctly.
Ghettobird52
Jul 5, 2024 11:18 PM
Cleotiz
Jan 6, 2018 08:56 PM
Omega
Aug 10, 2015 12:46 PM
novaderrik
Aug 10, 2015 12:44 PM
Fronzizzle
Aug 9, 2015 01:15 PM
