Turn Signal quit automatically shutting off
Old Nov 9, 2009 | 08:52 PM
DomesticCheese's Avatar
Car: 1984 Chevy Camaro & 1988 Trans Am
Engine: H/C/I LS1 & 305 LB9
Transmission: T56 Magnum-F 2.66 & Stock T5
Axle/Gears: QP 9" TruTrac 3.70 & Stock 10bolt
Hey all - tried searching but to no avail.
My left turn signal in the past couple days quit turning off by itself after making a turn.
The right one still works fine.
I have no idea how this mechanism works so I was hoping someone could shed some light on it for me?
Old Nov 9, 2009 | 09:13 PM
z28 TPI's Avatar
Car: '85 Camaro Z28, '90 300zx
Engine: 350 4 bolt main TPI
Transmission: 700 r4 automatic
Axle/Gears: ? not there yet, i know its stock
Re: Turn Signal quit automatically shutting off
Well you need to take the steering wheel off. Then just behind it there should be a metal plate the is held on by a small ring aroung the steering shaft. To take the plate off they make a tool or you can try to push the plate in, but its like 50# test spring or some insane amount. Anyways I would get the tool, the tool tells you how to back the plate off the shaft. After that just replace the white plastic sleeve called the turn signal cam that is the next piece, put everything back together and see if that was the prob. if not its the next white plastic device that is the turn signal switch. Any parts store has these things its very common item to break in the GM steering column.
Fronzizzle
Mar 18, 2019 08:29 PM
dibella989
Sep 1, 2015 04:12 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
