guage cluster issues
Old Nov 10, 2009 | 05:00 PM
13714 Trans AM's Avatar
Car: 1982 Trans Am
Engine: 305 4 barrel
Transmission: 4 Speed
i need help i picked up a trans am project and when i got it the gauges didn't work.
but it came with another 1 and all gauges work and the dimmer lights and the brake light. just not the others. its just the red brake light in the top right corner all the others are dead.
ne 1 have ideas on how to fix this or do i need to pick up another 1?
Old Nov 10, 2009 | 08:43 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: guage cluster issues
Can you explain again what works and what doesn't? Your description isn't clear, at least to me.
Old Nov 10, 2009 | 08:52 PM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
It seems like either there is a connection issue on the back of the cluster where the light bulbs tie in and are not getting power or you have multiple dead bulbs. On the back side, they just twist out and you can test them or put power to them and verify whether the bulbs are good or bad. Otherwise the cluster circuit grid/panel has issues or needs cleaning.
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
Accerrito22
Sep 5, 2015 09:34 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
andy74
Sep 3, 2015 08:41 AM
