84 instrument panel to 89
Old Nov 23, 2009 | 01:24 PM
rs89todd's Avatar
Car: 1986 Chevrolet Camaro
Engine: 355 chevy
Transmission: t-5
Axle/Gears: 3.73 disc brakes
hey guys im doing a swap to my 84 camro v6 from my 89 rs 5 speed 305 (body is too far gone) so im swapping everything over from ground fx to the motor and trans, but the instrument panel in the 84 is the kmp and mph on the other side and only goes to 140, and my 89 goes to 185, how far is it to switch everything over? what will i need? or will it not work cause of computer would like some adivce please
Old Nov 23, 2009 | 02:05 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 84 instrument panel to 89
Originally Posted by rs89todd
my 89 goes to 185
There were no OE 185's. Is this an after market?
JamesC
Old Nov 23, 2009 | 02:41 PM
rs89todd's Avatar
Engine: 355 chevy
Transmission: t-5
it looks stock, its got the 180 and then a half mark and says 185 so as far as i know been in there for 260k it looks like lol
Old Nov 23, 2009 | 02:49 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I'm guessing he has a Canadian speedometer. 115mph = about 184kph. His profile says Ontario. Speedo head swap should be plug & play.
Old Nov 23, 2009 | 03:22 PM
Convoy25's Avatar
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
didnt they change the design or something in 88?
Old Nov 23, 2009 | 03:27 PM
JamesC's Avatar
1st design (mechanical), 82-84
2nd (mechanial), 85-89
3rd (electrical), 90+
JamesC
Old Nov 23, 2009 | 04:31 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
You will need to pull the gauges, speedo, and tach ( Anything that you want to use ) from the 89 cluster and install them into your 84 cluster.
The 1989 clusters printed circuit is not completely compatable with the 1984 dash harness. If you try to simply plug the 89 cluster into the 84 dash than you will have problems with the backlighting as well as the BRAKE warning light. ( look where the BRAKE light is located on Each cluster ! )
Old Nov 26, 2009 | 12:16 PM
rs89todd's Avatar
Engine: 355 chevy
Transmission: t-5
so will it not work? or if it will just switch the gauges in the pods to make that work?, and yes my car is a canadian car,
Old Nov 26, 2009 | 06:01 PM
JamesC's Avatar
Note John's first paragraph.
JamesC
meeklay812
Oct 1, 2015 03:46 PM
kkirch15
Sep 30, 2015 04:44 PM
FormulaEngland
Sep 30, 2015 01:50 PM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
