Please help: Blower fan weirdness
Old Nov 30, 2009 | 03:58 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
My heater/A/C blower motor does not work on the fastest setting/position. It works on very slow and medium speed but then shuts off when I turn the switch to the last/fastest position.
I bought a new switch, but this still did not fix this issue.
Is there a relay that is responsible for the high speed setting or something? I'm clueless.
Any help would be greatly appreciated.
Old Nov 30, 2009 | 06:04 PM
5.SLOW's Avatar
Car: 1991 Z28
Transmission: 700-R4
Axle/Gears: 10 bolt Disc/Posi
Re: Please help: Blower fan weirdness
blower motor resistor.
Old Nov 30, 2009 | 06:28 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by New2Chevy
Is there a relay that is responsible for the high speed setting...
Yes. The resistors are in the low speed settings circuit.
JamesC
Old Nov 30, 2009 | 09:07 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
I think it's the relay, not the resistor pack. The relay runs high speed, the resistors are used for the other speeds.
Old Nov 30, 2009 | 09:08 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
JamesC
... and it's easy to find because it's on a bracket bolted either to (A/C cars) or near the blower housing. There is also a fusible link for the bugger as well...
Old Nov 30, 2009 | 09:42 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
OK, thanks guys. So the resistors are for the low speeds, and the relay on that bracket right by the blower motor is for high speed?
And where is the fusible link for the darn thing?
Old Dec 1, 2009 | 08:54 AM
Pocket's Avatar
Car: 91 Trans Am
On the starter
Old Dec 1, 2009 | 09:55 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
If the fusible link were bad, though, the thing wouldn't turn on, period...right?
Old Dec 2, 2009 | 09:10 AM
jv9999's Avatar
Engine: 5.7L/350
I think that fusible link is for all the accessories, not just the blower.
Old Dec 2, 2009 | 09:24 AM
Pocket's Avatar
Car: 91 Trans Am
Everything that is connected to a constant 12v source goes through a fusible link
Depending on the engine type, there are 3-7
Old Dec 2, 2009 | 10:30 AM
Engine: 2.7L V6
Axle/Gears: 4.41
Don't know about the V8's at the moment (don't have my FSM with me here), but my fusible link for the blower fan is actually at the junction block where the small positive cable connects along with the alternator BAT wire on stock cars... Yes, it's the stock location.
:edit: And yes, the blower motor is on its own fusible link...
Old Dec 2, 2009 | 11:46 AM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Right, but the blower motor wouldn't turn on AT ALL, if the fusible link was bad. I'll change the relay first then post what happens.
Old Dec 2, 2009 | 03:10 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Well I tested the relay with a battery and jumper wires, and it made a clicking sound, so I assume the relay is good.
I cleaned the plug and the relay terminals with electrical cleaner. If that doesn't work, then I am stumped.
Old Dec 2, 2009 | 03:15 PM
JamesC's Avatar
Check the following link for some great suggestions:
https://www.thirdgen.org/forums/elec...aro-rs-no.html
JamesC
Old Dec 2, 2009 | 05:39 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Actually, there are 2 separate circuits for the blower motor... The fusible link for the high speed is ONLY for the high speed. When I originally installed my 91 harness, I didn't have the high speed wire set up for the blower fan. The blower had all speeds except for high speed.
Just because the relay clicks doesn't mean it's good...
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
