Will a dash wire harness from a 89 work in a 91???
Old Dec 4, 2009 | 08:08 PM
STRIKER911's Avatar
Car: 89 RS
Engine: 305 TBI (lo3)
Axle/Gears: Whatever is stock.
Most likely the harness was the same but what about the air bag? Was that an entirely diff system? Any input? Thanks guys.
Old Dec 4, 2009 | 10:44 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: Will a dash wire harness from a 89 work in a 91???
i dont believe so if for no other reason that i know the speedometer changed to electronic from mechanical. If its close enough to be made to work idk but its not the same.
Old Dec 5, 2009 | 12:13 AM
STRIKER911's Avatar
Car: 89 RS
I knew about the speedo thing but I just figured it was a stand alone deal. U know like going from the speedo to the trans. But I guess It would be in the main plug on the drivers side that plugs in at the fire wall. Just not sure since I dont have a 90-92 car to look at. Anyone have one that could take a look?
Old Dec 5, 2009 | 11:38 PM
Pocket's Avatar
Car: 91 Trans Am
https://www.thirdgen.org/forums/ltx-...formation.html
I wouldnt suggest older wiring in a newer car
Old Dec 6, 2009 | 12:07 AM
STRIKER911's Avatar
Car: 89 RS
okay thanks for the help Pocket
Jorlain
Aug 24, 2022 05:11 PM
Vintageracer
Jan 10, 2020 05:33 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Reddeath210
Oct 6, 2015 08:20 AM
