missing plugs
Car: 84 z28 h.o./ 92 rs
Engine: 305 h/o /3.1 v6
Transmission: hybird turbo 350/t5 bog warner
Axle/Gears: non posi 3.73 / ls 3.42
missing plugs
did some eletrical work and found some plugs under my dash tucked away behind the driver side kick panel wtf ?!?
iam gunna pull the kick panel when it stops raining here !
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Hocus Pocus Learn How To Focus
The bottom pic: that connector will accept a SPDT relay.
Hopefully others will chime in and recognize the other ones.
Happy Racing!
If People Drove Any Slower Theyd Be Going Backwards
When you see fog lights on in good weather beware. Low performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime, and the nitwits that need headlights for a little rain
Happy Racing!
If People Drove Any Slower Theyd Be Going BackwardsWhen you see fog lights on in good weather beware. Low performance driver ahead.
Re: Hocus Pocus Learn How To Focus
that nina i think the ic cam out like that bc the camera was dying i'll take better ones
tomorrow ! the relay you speak of
do you have a pic of it ?
what does it do ?
thanks again ?
what does it do ?
thanks again ?
Transmission: 765R4
Hocus Pocus Learn To Focus
I dont have a pic however its a 1 black cube.
All well stocked part stores sell them.
Just ask for a 12 VDC Tyco or Bosch Relay SPDT
I dont what the relay did in your car.
If everything in your car works, the relay was probably for an addition installed by the PO, which was removed before selling the car.
Happy Racing!
Happy Racing!
Re: missing plugs
First connector is power to the power windows/mirrors
Second is a relay of some sort. Judging by the type (as Nina posted) Id guess foglights as the wiring and colors look stock
Re: missing plugs
ok chillia dont have power windows or mirrors !
i'll try and get the spdt resitior this weekend ! thanks again nina and pocket !
Car: '88 Black GTA, T-tops, digital dash
Engine: 5.7 TPI w/custom chip
Axle/Gears: 9 bolt 327 posi
Re: missing plugs
When I've seen these "empty" plugs I've always thought it's for other accesories to be added later on. Does that make sense? I wouldn't worry about them unless something in the car doesn't work.
Re: missing plugs
thanks dave i think the same way but really i just wanna know for refrance bci do have a 84 with power everything and my 92 rs is havin eletrical problem too like my lights and my ac and heat so iam just coverin all bases thank for the input dave!
Re: missing plugs
You're welcome! I hope you get everything working right soon.
eightsixseven
Dec 16, 2024 01:50 PM
