2 Probs: 1. Gas Guage | 2. Fog Lights
Old Dec 21, 2009 | 05:12 PM
Slash's Avatar
Car: 1988 Camaro IrocZ
Engine: Holley Stealth Ram 385 Stroker
Transmission: Redline Performance 700r4 Trans
Axle/Gears: Bulletproof 4thGen Ls1 SS Rear 3.73
1.
When the gas tank is completely full the gauge only reads 3/4th full. and it does move so it's not stuck or anything, it's like it's timing or w/e is off.
so as u can guess when the car gets down to reading near empty you can't help not to get edgy(even tho in retrospect theres 1/4th tank). After a bit it jus gets sketchy reading empty yet still goin u dno when u'l run out.
Would this mean i need a new fuel sending unit/guage or what idk much when it comes to this particular stuff.
2. When purchased car from previous owner 3weeks ago the fog lights didnt work, and he said he had disconnected them b/c of that. i went all throughout the possibilities that the bulbs were bad, the ground, faulty wiring, something wasn't hooked up right the works. no blown fuses couldnt find or see something wrong.
i called up the previous owner and he said he used the fog lights everyday b/c he loved the look and just one day they never turned on and stayed that way, he couldnt figuyre it out either so he ended up disconnecting them.
any ideas?
Help on either or both problems would be very appreciated
Thanks and happy holidays,
Sean
Old Dec 22, 2009 | 02:55 PM
Slash's Avatar
Re: 2 Probs: 1. Gas Guage | 2. Fog Lights
bump, help ?
Old Dec 23, 2009 | 02:15 PM
Slash's Avatar
bump..
Old Dec 23, 2009 | 02:27 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Probably not the cause, but at least the info will get you a bump: From 86 up, the fog lights function with the parking lights or with the low beams, but not with the high beams.
You may find the following link useful:
http://www.austinthirdgen.org/index.php?pid=19
JamesC
Old Dec 26, 2009 | 05:36 PM
Davidgou's Avatar
Car: '88 Black GTA, T-tops, digital dash
Engine: 5.7 TPI w/custom chip
Axle/Gears: 9 bolt 327 posi
Thanks for the link JamesC that's a nice diagram there. And Slash, looks like your sendint unit needs adjustment, but it's a hazzle to do.
Old Dec 31, 2009 | 09:54 PM
hotbird89's Avatar
Car: 90 Trans Am
Engine: 5.0 TPI- slightly modified...
Transmission: Modified 700-R4
Axle/Gears: 10 bolt 3.23 eaton posi moser shaft
Check the resistance on the sending unit at the wires in the dash, there is a specific reading for a certain fuel level. Unfortunately there is no adjustment to be made on the sending unit, and they are EXPENSIVE and HARD TO GET TO. I had the same problem, and it was the guage itself.
The fog lights used a relay, located on the driver side, about 8" in front of the firewall mounted on the inner fender. When the relay is bad, they won't work, they also won't work on high beams either like JamesC said.
jaridjohn
Jul 8, 2024 03:49 PM
Ghettobird52
Jul 5, 2024 11:18 PM
PATRIOTIC1911
Sep 1, 2015 07:26 PM
mustangman65_79
Aug 12, 2015 06:39 AM
Omega
Aug 10, 2015 12:46 PM
