87iroc... can you add factory cruise??
Old Jan 1, 2010 | 11:51 PM
classof87z's Avatar
Car: 1987 IROC Z bone stock
Engine: L98 TPI
Transmission: stock
Axle/Gears: stock
Looking for some info.... I have an 87iroc and was wondering if factory option cruise can be added or is this waaayy too much of a headache and expense. I noticed that the speedo cable has a union just below the master cyl. and the throttle cable/trans kickdown cable bracket has the hole for the additonal cable and the throttle lever has the attaching point. Any guidance is appreciated.....
Old Jan 2, 2010 | 10:03 AM
Pocket's Avatar
Car: 91 Trans Am
Re: 87iroc... can you add factory cruise??
Its easy to add
Parts needed
3rd gen cruise head, cable, bracket
cruise harness
cruise signal stalk
Old Jan 2, 2010 | 05:27 PM
Drew's Avatar
87 shouldn't use the split in the speedometer cable... It should get it's VSS signal from the dash cluster. You should be able to get the parts from a donor car and most of it will connect directly to the car. For 87 most of the cruise should be self contained, in the later cars it really becomes an intergrated part of the dash harness. Try to find a donor car as close to the same year as possible, since the design and layout changed several times between 82 and 92.
Old Jan 5, 2010 | 07:54 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
You will also need a cruise Module/Harness, and the correct brake switch as well. ( installed under/behind the dash housing ) I'm pretty sure that 84-88 is a good range for donor parts.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
SlowAZ28
Sep 2, 2015 05:19 AM
