wiring harness labeling?
Car: 1987 Firebird, Dad bought it new
Engine: 5.7L Vortec w/ LT4 Hot cam
Transmission: 700r4 transgo shiftkit 2600 stall
Axle/Gears: 3.42 '02 SS 6 spd rear
does anyone know if theres someone i can send my wiring harness to, to get it labelled so i can just plug it in where it goes, i have a super complete harness from a 1987 GTA LB9/70024 car but i have no idea what most of the stuff is and if it were labeled it would make my installation 500x easier, unless someone wants to come to PA and help me install it lol thanks in advance
Re: wiring harness labeling?
When you go to plug everything in, the harness will fall into place. You can usually figure out what each connection is for with a shop manual and some deductive reasoning, but you can spend hours doing it and it makes a lot more sense when you just drop it into the car. If you run into a plug without a home in the process it'll be a lot easier to just post a picture of the plug and ask where it goes. There isn't a lot of danger involved, since most of the plugs will only plug into the correct device.
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
well im not sure about that, but if you can get a dealer service manual that would help ALOT otherwise i think painless has a kit thats labeled but ya know thats some $$$$, maybe get lucky and find one for sale or in a j/y localy and look at it and take alot of pics
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
1. go to motors.ebay.com
2. in search type in: tpi harness
3. watch all connectors listed and compare with your harness
DIY and free
best regards
DIY and free
best regards
thanks alot guys this was all very helpful info i think i can manage pretty good from here, illl just plug it in and see what happens then ill just try to find out what wont go i wasnt sure about the connectors fitting different sensors so that set my mind at ease alot,
