84 camaro alternator problems
Old Jan 10, 2010 | 01:48 PM
karatebobby's Avatar
Car: 1988 Camaro
In my 84 camaro there is a 350 small block put in before i bought it. the alternator fried when my idiot friend hooked up the jumper cables back words and i need to know where i ground out my alternator.
Old Jan 10, 2010 | 01:56 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 84 camaro alternator problems
The alternator is grounded through the case.
Old Jan 10, 2010 | 01:59 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
it just grounds to the engine through the mounting bolts
-anything else get fried because of the reverse hook-up?
Old Jan 10, 2010 | 02:06 PM
Car: 1988 Camaro
alright so then the only thing i need to do is connect it to the positive battery terminal and connect the v belt? and the battery was junk ofcourse too
Old Jan 10, 2010 | 02:48 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
And the case connector, and you'll probably want to check your fusible links, too.
92camaroJoe
Jul 29, 2023 07:57 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Fronzizzle
Aug 9, 2015 01:15 PM
