Gray fuel pump wire?
Old Jan 15, 2010 | 07:43 PM
trueburton's Avatar
Car: '88 Red Trans Am w/ T-tops
trying to diagnose a bad fuel pump. I have 11v at the purple wire. but nothing at the gray wire. where does that wire get its voltage from? thanks
Old Jan 15, 2010 | 09:45 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Gray fuel pump wire?
If it's the wire I think it is, it gets power either from the fuel pump relay or the oil pressure switch.
Old Jan 16, 2010 | 10:31 AM
trueburton's Avatar
would that only have power when the key is first turned on and then nothing or should it always have power?
Old Jan 16, 2010 | 02:34 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Has power for 2 sec with the key turned on (unless the engine is running), and with the oil pressure switch closed... Otherwise, your fuel pump would always run.
Old Jan 17, 2010 | 03:42 PM
trueburton's Avatar
thanks
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
