1991 firebird. 3.1 L
Old Jan 26, 2010 | 11:19 AM
lance1126's Avatar
Hey guys i have recently purchased a 91 firebird. it ran fine for the first couple weeks and then it started sputtering when idling and then one day i was in traffic and it got really hot and now it won't start back up. i've changed all the sensors relating to the error code 23 its giving me with no luck. and i took the fuel rail apart and found out that the injectors aren't firing. I'm thinking its a computer problem but not sure. anyone have a similar problem that they might know why its doin it. i'm thinking its either the computer or the harness but not sure.
Old Jan 26, 2010 | 11:43 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Injection Rejection
If you’re getting spark disconnect one injector and connect a test light to the harness connector terminal.
Repeat procedure with the other bank.
Did both banks blink the test light?
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog or “running” lights on in good weather beware. Low performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime, and the nitwits that need headlights for a little rain
Old Jan 26, 2010 | 02:40 PM
lance1126's Avatar
Re: 1991 firebird. 3.1 L
thanks i'll check it out when i get back home in a few weeks. i did use the test light to see if the sensors were working and they did so thats why i thought it was the computer. from what i understand the wiring harness for the sensors is the same harness that controls the injectors thats why i think its the computer
Old Jan 30, 2010 | 11:34 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Repeat the test on the other injector terminals with a test light connected to battery positive. Crank the engine, and note whether the test light blinks. If the test light stays off during this, connect to a different terminal, as you need to find out whether the ECM is grounding the injectors, not whether the ignition source is reaching them.
Linson
Oct 24, 2025 02:00 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
mcfastestZ28
Oct 5, 2015 07:12 AM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
tattmann
Sep 27, 2015 05:20 PM
