85 Camaro MAF Sensor Q?
Hi, Newbie here. Had a couple Vetts a few years ago and just got the itch for an old Camaro. Just picked up an 85 IROC for $1K and think I have a 215 horse money vacuum - just like the Vetts. Getting a MAF error on the ECM and wonder about testing this thing. Anybody know how? Its just a hot wire that changes resistance - can't be rocket science. Any of these available used and what years will bolt in?
MarineDeuce
MarineDeuce
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
It IS rocket once you modify it to go like a rocket.
A clean, rebuilt & tested one is only $67 so why bolt on an unknown?
Happy Racing!
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog or “running” lights on in good weather beware. Low performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime
and the nitwits that need headlights for a little rain
If People Drove Any Slower They’d Be Going BackwardsWhen you see fog or “running” lights on in good weather beware. Low performance driver ahead.
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: 85 Camaro MAF Sensor Q?
Any 85-89 MAF will work. The 85 is a year-specific item that included that ridiculously expensive burnoff module that was prone to failure. The 86+ style MAF got rid of the burnoff module. I've run a number of 86+ MAFs in my 85 and they worked well.
Hi Jim
I had a reply from NINA saying rebuilts are available for $67. Sounds good to me especially if an 86 will work straight up in my car. Is the plug the same or will I need to rewire? Who does these rebuilds - I'm not finding much just surfing Camaro parts sites. Thanks again for the info.
MarineDeuce
MarineDeuce
Car: '85 Camaro/08 Hond./99 Mack Truck C
Engine: 5.0/4 cyl. in-line/Cat. Diesel
Transmission: A/OD,/A/OD,/Automatic,no O/D...
Axle/Gears: 2/2/and 4 OD, OD, auto.
Re: It IS rocket once you modify it to go like a rocket.
Not necessarily "sir" some states by law require lights on during inclement weather.
So, respect others, it does a body good.
NBrehm
Aug 25, 2015 11:49 PM
mdtoren
Aug 16, 2015 05:45 PM
