Headlights wont work
Car: 83 Camaro
Just got myself an 83 camaro, no headlights. i replaced the headlight switch and still nothing. also if there is a headlight relay where is it located. also the yellow wire to the headlight switch is that the wire for the headlights? it looks like it in my diagram in my repair manuel. should i fallow it to see if its a short, or a bad ground? also would the high beam low beam affect anything at all with the lights not working, since all my other lights work but the headlights. thanks
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Headlights wont work
Did you try running 12v directly to the bulbs to see if they burn at all? Maybe just need bulbs.
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
check the dimmer switch assembly
do the brights work?
if so then i vote for bad dimmer switch
Ghettobird52
Jul 5, 2024 11:18 PM
The_Phoenix
Feb 4, 2016 07:10 AM
