Interior lights
Old Feb 1, 2010 | 04:19 PM
rdsxfn524's Avatar
Interior lights
1985 Trans Am the lights on the inside of the car do not turn off even if I check all doors how can I fix the problem???
Old Feb 1, 2010 | 05:50 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Interior lights
Are they off at the headlight switch?
JamesC
Old Feb 1, 2010 | 07:12 PM
rdsxfn524's Avatar
Re: Interior lights
They are on whatever you do
Old Feb 2, 2010 | 09:50 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Hey It’s Too Bright In Here
Divide And Conquer
To locate the offending circuit connect a meter (a digital one will be the best for this problem) to the dome light across the contacts, keeping the lamp in the circuit therefore illuminated.
Keep both doors open, engine off.
One at a time, push in and release the left door switch, then the right door switch, then open and close the headlight switch interior light contacts.
The offending circuit will NOT cause an increase in voltage.
When you locate the offending circuit you just have to trace that one down for the short.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog or “running” lights on in good weather beware. Low performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime and the nitwits that need headlights for a little rain
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Omega
Aug 10, 2015 12:46 PM
