Couple of Problems?Help Needed Please
Old Feb 2, 2010 | 05:42 PM
david_beast's Avatar
Car: 1985 Trans Am
Engine: 350 Small Block
Hey guys,I just bought a 1985 Trans Am,Very nice ride!!!Just a couple of problems here and there...
1.) Why are my windows rolling down so slow??In this forums,I saw somebody's post about removing dust particls or sumthing from the motor so that it would run faster,I looked everywhere but no luck...Can Anybody help me with this?
2.) Where is the trunk button located at?The place to put the key in my trunk is rusted out and i cant figure any other way in opening it other than finding the switch for the trunk button.
3.) How do i replace the headlight motors?Where is the motor located at?
4.) Is there a seatbelt recall for 1985 trans ams because mine dont work at all.
5.) Do u guys know where i can get cheap weather stripping equipments?
I am sooo sorry for so many question,I am illiterate about cars and I am planning on working on cars.
Thanks you very much for ur Help!
Old Feb 3, 2010 | 06:44 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: Couple of Problems?Help Needed Please
Ok well here goes ill try to answer these in a way that makes the most scene lol.
1. Power windows:
If a motors working slowly theres a few possabilities that all stem from 2 basic issues too much load on the motors and power losses that do not contribure to the motors functionality. The first one is pretty self explanatory if the mechinisms in the door dont operate freely then the motor will be bogged down. The second is not so easily understood but here goes lol. It takes energy to do work in this case the desired use of energy is in the motor to open the windows. However there are losses caused by resistances in the wire stuff like that and although these losses should be very small if theres a problem like a bad ground with high resistance alot of energy that would have normally been used in the motor to open the window is being used to overcome the resistance to ground there by making the motor operate slowly because its only getting some of the energy it should be getting. Although i have not heard of much in the line of taking the motors apart and cleaning them its probably possible and there are places inside the motor losses can occur that cleaning may correct although if that was the case i personally would just replace it. If im not mistaken these motors arnt too expensive anyways.
2 Trunk:
The button (if it has a power trunk option) would be located in the dash under the far right 2 gauges.
3. Headlight motors:
The headlight motors are next to the headlights themselves. If you look under the hood and find the **** that manually allows you to operate the headlights that **** is part of the motor.
4. Seat belt recall:
Yes there actually was a seat belt recall on the 85 T/A as well as many other camaros and firebirds. Some persistent people have had luck taking them to the dealer for the fix even though these cars are so old but its a hit or miss kinda thing and the ones that do often times just get new seat belt recievers that are left over in stock but you wont likely have your choice of color.
5. Cheap weather stripping:
Unfortunately there is none. In all my years of dealing with these cars i have never not once heard of a cheap source of weather stripping or heard of anyone else finding one. Maybe someone else will chime in here but I think your going to be pretty SOL here.
Old Feb 3, 2010 | 06:55 PM
87_ta_305_4bbl's Avatar
Car: 87 Trans Am
Engine: 305 4bbl
Axle/Gears: 10 bolt 3:52
cheepest i have found was at year one dont know there phone number but the web site is yearone.com
Old Feb 3, 2010 | 08:13 PM
Car: 1985 Trans Am
THANKS U GUYS,THIS WAS GREAT HELP!!
Old Feb 4, 2010 | 07:45 AM
uemf's Avatar
Car: '86 Firebird
Engine: '85 TPI on crate 350
Transmission: T-5 man
The cheapest I've found weather stripping is here.
www.dannoenterprises.com
He sells Metro weatherstripping kits.
K82FHT
kit
82-92 Seal Kit (M)
Kit includes: 1 pair door seals, 1 pair roof rail seals & 1 hatch seal
All Models
(Does not fit T-Top)
$135.00
Old Feb 6, 2010 | 04:02 PM
Car: 1985 Trans Am
Appreciate it!!
IROCZ1989
Jan 24, 2016 03:55 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
Fronzizzle
Aug 9, 2015 01:15 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
