no low beam lights on 89 Camaro only highs work
Old Feb 4, 2010 | 03:45 PM
Jesse076's Avatar
Car: 89 Camaro Vert all stock
Engine: 350 TBI(previously 305 LO3)
Hello Guys I have a dumb question...my high beams work fine but my lows (regular lights) do not. Its not a fuse checked that so I am not sure..the side lights work but not the front headlights... I have an 89 Camaro Convertable with TBI no mods yet until I can get these little electrical problems fixed.
Thanks for your help.
Old Feb 4, 2010 | 11:11 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: no low beam lights on 89 Camaro only highs work
try tilting the wheel all the way up or down - if you have tilt it makes adjusting the switch a pain in the keister. if no tilt, then your switch needs adjusted - it's under the column above the brake pedal - it's a bear to get to - you'll see the actuating rod to the switch if you move the lever while looking - that switch assembly imoveable - just loosen bolts and move slightly up towards the steering wheel.
Old Feb 5, 2010 | 07:19 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
And the problem could originate in the switch itself.
JamesC
Old Feb 5, 2010 | 01:04 PM
Jesse076's Avatar
Ok i looked by the brake peddle and I seen a rod attached to the brake pedal that goes through the firewall into the engine compartment is this the rod that needs to be disconnected? and reconnected? Oh yeah I do not have a tilt column...Thanks.
Old Feb 5, 2010 | 01:19 PM
JamesC's Avatar
No, the rod in questions goes down the steering column into the switch, which is also located on the column.
JamesC
Old Feb 5, 2010 | 01:39 PM
Jesse076's Avatar
ok i found the rod on the column so do I just loosen the bracket that the switch is mounted to? How do I adjust the rod?Do I disconnect it and reconnect? I am not sure how to adjust now that I have found it...Thanks for your help.
Old Feb 5, 2010 | 01:53 PM
Car: 1992 RS
Engine: Carbed 350
The switch slides a tad - just loosen the 7mm bolthead and move it up towards the steering wheel a wee bit, retighten and test - until you get it right.
Old Feb 5, 2010 | 02:17 PM
Jesse076's Avatar
GREAT!! thanks for your help I will definatly do that.
Thanks again everyone for your help and insight.
84z96L31vortec
Aug 20, 2017 12:16 AM
jackhammer
Aug 15, 2015 10:04 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
Omega
Aug 10, 2015 12:46 PM
