Electronic Odometer Help!
Old Feb 15, 2010 | 12:35 PM
88gta_hiflyer's Avatar
Car: 1988 GTA
Engine: 305 tpi (LB9)
Transmission: WC T-5
Axle/Gears: 3.45 posi
Ok I'm stumped on this one. My odometer stopped at 84,xxx and I need to fix it. The car is an 88 GTA and has a 145mph electronic speedo. The speedometer works fine as do all the other gauges and the trip will reset but the odometer is frozen. I did a search on this issue but only found fixes for the cable diven speedos. I really don't want to swap out the entire cluster. I'm really not sure where to start so any help would be greatly appreciated. Thanks in advance.
Old Feb 15, 2010 | 12:55 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: Electronic Odometer Help!
Edit: I misread, I thought you had the digital dash. There is a small electric motor that drives the odometer, it has probably stopped working. The easiest fix is to get a spare speedo, change the mileage to match, and swap it in.
Old Feb 15, 2010 | 01:34 PM
Car: 1988 GTA
Is there a way to match up the mileage? That's really my biggest hesitation about swapping speedos because I really want to keep the mileage as acurate as possible. Also, I know if I ever find another 145 speedo with that mileage that low it won't be cheap either. Is it possible to swap out just the little electric motor?
Old Feb 16, 2010 | 11:37 AM
Car: 1988 GTA
Anybody?
InfernalVortex
Apr 20, 2021 11:31 AM
MrPackstin
Oct 25, 2017 08:09 PM
1992Z28!
Nov 19, 2015 07:33 AM
anesthes
Sep 30, 2015 07:48 AM
PestilenceIV
Sep 22, 2015 07:39 PM
