Need some help with strange headlight issue
Old Feb 15, 2010 | 11:53 PM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
I have a 1991 Z28 vert and my headlights just started doing something pretty weird. I turn on the headlights, and they work fine. However, when I turn on the high beams, both high beam lights come on, but the passenger side low beam light stays on as well...the driver's side does as it should and shuts off. Has anyone had this happen to them?
Anyone out there got any tips for fixing this, I'd appreciate it. Thanks
Old Feb 16, 2010 | 12:28 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: Need some help with strange headlight issue
wrong. your driver side high is burnt out, the way they are suposed to operate is:
lows - two outer lights on
highs- all 4 light up
Ive got the same issue your head lamp is simply half burnt out you can get a replacment for like $20 at autozone
Old Feb 16, 2010 | 12:34 AM
interesting...i don't seem to remember any time where both lights were on at once. but, then again, i never use the high beam on the car, but it has to work to pass state inspection. i'll have to look into it some more.
Old Feb 16, 2010 | 07:23 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I couldn't remember either, so I went out and tried the lights. The highs and lows are never on at the same time.
JamesC
Old Feb 16, 2010 | 10:19 AM
hmmm...well, i guess i have an issue somewhere then. who knows how long its been like that, as i said, i never use the high beams. could have just started, could have been like that for a while.
anyone have any suggestions on what my problem may be? the circuit doesn't look too complicated, so hopefully it isn't anything major.
Old Feb 16, 2010 | 10:22 AM
JamesC's Avatar
You might check the following thread as it deals with a similar problem:
https://www.thirdgen.org/forums/elec...t-problem.html
JamesC
Old Feb 16, 2010 | 01:34 PM
Shadyredeyes's Avatar
Car: 1987 Camaro Iroc Z28
Engine: 350 S/B
Transmission: 700 R4
Axle/Gears: 2.43 Gear Ratio
On my '88 S/C low beams are outside only, and high beams are all four as well.
Old Feb 16, 2010 | 02:59 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
uh oh, somebody jacked up my lights then oh well, i light having all 4 light up lol
Old Feb 16, 2010 | 03:34 PM
Engine: 350 S/B
Mine is probably fubarred as well. When I first bought the car my low beams worked properly, but my highbeams would light up both sides on the drivers side but only the outside low beam on the passenger side. I found a ground wire near the lights cut, so I soldered it to my high beam on the passenger side and now all four come on whenever I have high beams on. May not be right but I like it too!
Cornholio7979
Sep 20, 2018 02:31 AM
PATRIOTIC1911
Sep 1, 2015 07:26 PM
someone972
Aug 30, 2015 12:52 AM
red90IROCls1
Aug 25, 2015 06:56 AM
Fronzizzle
Aug 17, 2015 02:52 PM
