Headlight problem????
Old Feb 15, 2010 | 03:13 PM
POPODYNAMO's Avatar
Car: 84 Camaro Z28
Engine: 305 HO
Transmission: 700-R4
Hello i was working on my 84 Z and i finally got my dimmer switch to work and was testing everything out and i noticed that the inner headlights werent turning on and idk wat they are used for, cause i know in 84 they didnt have foglights.
Old Feb 15, 2010 | 03:31 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Headlight problem????
Inner = high beams
outer = low beams
Highs or lows will be on, but not both at the same time.
JamesC
Old Feb 15, 2010 | 05:49 PM
POPODYNAMO's Avatar
Car: 84 Camaro Z28
Engine: 305 HO
well when i turn on the high beams the outer lights just flicker up and the low beams stay on the outside and flicker down. Idk if its something in the wiring or wat.
Old Feb 16, 2010 | 10:10 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
No Light ?. . . . Outa Site !
If they just flicker you might have a bad dimmer switch, or loose wiring going to it.
Use a voltmeter at the output of the switch to find out which one it is.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog or “running” lights on in good weather beware. Low performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime and the nitwits that need headlights for a little rain
Old Feb 16, 2010 | 10:21 AM
POPODYNAMO's Avatar
Car: 84 Camaro Z28
Engine: 305 HO
Re: No Light ?. . . . Outa Site !
well i mean they dont flicker they stay on its just the inside headlights dont come on at all
Old Feb 16, 2010 | 10:23 AM
JamesC's Avatar
Perhaps the dimmer switch (at the bottom of the column) isn't adjusted correctly.
JamesC
Old Feb 18, 2010 | 10:24 AM
JamesC's Avatar
Popo, in reply to your PM, check the following:
Headlights
Circuit Operation:
Voltage is applied to the light switch at all times. The light switch includes a self-resetting circuit breaker which opens and closes if the headlight circuit draws too much current. When the light switch is in "Head," the headlight dimmer switch directs current to either the lo beams or the hi beams. Current to the hi beams also flows to the high beam indicator.
Troubleshooting Hints:
If only one headlight doesn't work in both "hi" and "lo", check the ground wiring.
If headlights don't work in just "hi" or just "lo", check headlight dimmer switch.
If headlights flash on and off with switch in "head," isolate short to ground. Operate the headlight dimmer switch to find if the short to ground is in tan or lt grn wires.
If only the "hi'" headlights flash on and off, check lt grn wires for shorts to ground.
If only the "lo" headlights flash on and off, check tan wires for shorts to ground.
If both "hi" and "lo" headlights flash on and off, check the yel wire for a short to ground.
JamesC
Old Feb 18, 2010 | 04:09 PM
POPODYNAMO's Avatar
Car: 84 Camaro Z28
Engine: 305 HO
Thanks James lol. When i get home i will take a video of me clicking the dimmer switch and see if u can see it better. Oh Ya can u upload videos on here??? To a thread
Old Feb 19, 2010 | 07:25 AM
JamesC's Avatar
Since the high beam indicator changes, power seems to be running through it as it should. The highs, however, don't turn on. Is that correct?
JamesC
Old Feb 19, 2010 | 03:50 PM
POPODYNAMO's Avatar
Car: 84 Camaro Z28
Engine: 305 HO
yes that is correct lol
Old Feb 19, 2010 | 04:01 PM
JamesC's Avatar
And you've replaced and adjusted the dimmer switch at the bottom of the steering column?
JamesC
Old Feb 19, 2010 | 05:00 PM
POPODYNAMO's Avatar
Car: 84 Camaro Z28
Engine: 305 HO
i adjusted it i didnt buy a new one yet
Old Feb 20, 2010 | 06:52 AM
JamesC's Avatar
When you pull the stalk to hi, do the lo's turn off completely?
JamesC
Old Feb 20, 2010 | 09:52 AM
POPODYNAMO's Avatar
Car: 84 Camaro Z28
Engine: 305 HO
idk It didnt use to work but when i finally got to it and loosened it up i just pulled the lever back to see if it worked and i heard a pop and it just moved back thats when it started to work but thats when i seen the inner lights werent working.
Old Feb 20, 2010 | 10:11 AM
JamesC's Avatar
When my dimmer switch went bad, if the lo's were on and I switched to high's, nothing at all worked. Blackness. (I found that out in pre-dawn darkness. Scared the bejeeus out of me.)
JamesC
Old Feb 20, 2010 | 10:22 AM
POPODYNAMO's Avatar
Car: 84 Camaro Z28
Engine: 305 HO
HAHA lol so is it a bad dimmer
Ghettobird52
Jul 5, 2024 11:18 PM
GTAman
Mar 15, 2019 11:40 AM
DiabolicalRS
Aug 26, 2015 07:35 AM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
