Starting problems
Old Feb 16, 2010 | 07:33 PM
rjshull's Avatar
Starting problems
Was driving my 88 bird earlier today and the check engine light came on. Stopped and turned the car off for 10 minutes and tried to start it back up and it acted like it had a dead battery. 2 weeks ago I replaced the battery so I figured the problem was the alternator. Checked the voltage at the battery with my fieldpiece multimeter and said I had 12.9 volts.
Tried to start it back up and I dont have power anywhere as I dont have the click from the starter or even the dome light. So I checked volts to ground and have 12, volts at alternator and have 12. With out jacking the car up to check at the starter what can I do to find the problem, if I need to check at the starter it will have to wait until tomorrow.
Any help would be appreciated.
Old Feb 16, 2010 | 07:44 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Starting problems
its gotta be a bad cable or fuselink
Old Feb 17, 2010 | 10:52 AM
rjshull's Avatar
Yep found it, bad battery cable going to the starter.Here is the weird part, Auto-Zone, Advance, and O'Reilly's says the cable should be about 45" but the one I just pulled off the car is about 91" and the longest ones they stock is about 65", guess I will have to have one made by napa.
Old Mar 31, 2010 | 02:17 AM
fr3ed0m's Avatar
Car: 92 camaro rs , 72 c10 longbed
Engine: 383
Transmission: 3 on the tree
Axle/Gears: 12 bolt with 3.73 gears/open diff
Yeah i just bought the longest one autozone had and it was no where near long enough for my positive side so used it on the negative side, Guy i bought it from had a side post one one side and top mount of the other cable cant remember witch but it was annoying me so we changed it today, still need to buy a starter relay as mine is missing I believe. I searched and another post said yellow wire goes to relay first so ill double check tomorrow just to make sure thats what is causing my starter to not work
Old Mar 31, 2010 | 02:20 AM
a 91" cable? mine is like 40"
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
