aftermarket guages.
Old Feb 20, 2010 | 01:23 AM
Ilike2stroke383's Avatar
Car: 1987 Gta Trans Am
Engine: 383 Stroker
Transmission: t-56
Axle/Gears: 3.47 02 SS rear end
aftermarket guages.
I have a 87 trans am. only thing that works on the panel is the tach... Im thinking about replacing the guages but cant decide what to do. I can mount them in the places the stock guages are, a little harder but neater. Or i can mount them around. Such as two guages on the pillar (fuel level and volts), mount the oil pressure and water temp where hvac goes, and electric speedo and tach on the top of dash somewhere. whats better?
Old Feb 21, 2010 | 12:27 PM
Engine: 383 Stroker
Transmission: t-56
Re: aftermarket guages.
Old Feb 22, 2010 | 08:44 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Mounting aftermarket gauges in the factory location is the way to go. I did this and love how it looks and having gauges that work.
https://www.thirdgen.org/forums/inte...ter-gauge.html
Old Feb 22, 2010 | 10:36 PM
Engine: 383 Stroker
Transmission: t-56
man that looks sweet. how much did that run you?
Old Feb 23, 2010 | 07:18 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
For the panel supplies & gauges it was about $500, and half of that was just for the speedo. That's without the pillar gauges (a/f ratio & boost) and minus the fuel pressure gauge that most people wouldn't use. I bought most of the gauges brand new off eBay or through craigslist to lower the costs a bit. This is one of the best mods you can do for the interior.
Old Feb 23, 2010 | 07:51 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Slick!
JamesC
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
