bad eletrical connection
Old Feb 23, 2010 | 09:41 AM
maro305's Avatar
well the other day i got my 1989 comaro rs 305 tbi running well but when i go and touch the wires to the coil pack it turns the car right off. and my check engine light is on and says code 42 so i think my problem lies in a bad connection at the coil pack any ideas of how to get a better connection.. i just baught brand new wires coil pack and dizzy its a mounted coil not hei
Old Feb 23, 2010 | 12:19 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Bad Wire No Fire
It sounds like one end of the primary has an intermittent connection.
With the engine off, use an ohmmeter with alligator clips to check the continuity of each low voltage wire.
Connect the alligator clips just past where the wires are crimped in the connectors.
The alligator clips will hold the ohmmeter leads in place to allow you to wiggle the wires until you find the faulty one.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog or “running” lights on in good weather beware. Low performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime and the nitwits that need headlights for a little rain
Cornholio7979
Sep 20, 2018 02:31 AM
bryanwood74
Sep 24, 2015 09:50 PM
mddaniel
Sep 8, 2015 05:16 PM
Slush92RS
Sep 2, 2015 08:56 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
