Wont start, need some help
Old Feb 23, 2010 | 06:11 PM
Seanmay1's Avatar
Car: 89 Firbird Formula WS6
Engine: TPI 305
Transmission: T 5
Axle/Gears: 3.45 Posi 9 bolt
Every so often my car has this issue. Turn the key and it wont start, everything inside of the car works, dash lights come on, but starter wont engage. Its like im not pushing the clutch in, well i unplugged the clutch safety switch and jumped it over. I had thought that was the problem because it hasn't done that in awhile. Well it has done it twice in the past week, after a few hours it will start up fine and will be find for awhile. What else do i need to look for other than the clutch switch? Is there a second switch somewhere on the clutch? ignition switch? vats? Need to figure this out so i can get it running tomorrow, car is sitting in a parking lot about 5 minutes from my house, cut it off and came out 5 min later and it wont do anything
Old Feb 23, 2010 | 06:18 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: Wont start, need some help
when this happens have you noticed if you move the steering wheel up or down... ? I would lean more toward an ignition switch, don't get it confused with the ignition lock cylinder...
Old Feb 23, 2010 | 06:31 PM
Seanmay1's Avatar
Engine: TPI 305
Transmission: T 5
Haven't even paid any attention to what im doing with the column when it happens. I will pick up a ignition switch, thats only $12.50, I know its not the lock cylinder, where exactly is the ignition switch? what all has to be removed to get to it?
EDIT: actually everytime i get out of the car i tilt the wheel all the way up, and bring it all the way back down when i back in
Old Feb 23, 2010 | 06:35 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
well on an 85 camaro it was right smack on the steering column.. I take it will be in the same place on this one...
Old Feb 23, 2010 | 06:56 PM
Seanmay1's Avatar
Engine: TPI 305
Transmission: T 5
well i will be finding it tomorrow, bad part is i wont be able to know for sure if that was the problem. I guarantee the car will crank in the morning and be fine for awhile. So after i change the switch i will just have to drive it for a few weeks and see if it does it again
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
