gauges don't work
gauges don't work
so when i got my z, there were a lot more problems than i anticipated. one of the main problems is that none of my gauges work. what do you guys think it might be? also, my tail running lights don't work...any suggestions? i think that might be a bad light push switch, but who knows. any thoughts you have are appreciated.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: gauges don't work
JamesC
well, the speedometer/tachometer just pegs out as soon as the car is turned on, and the others don't read anything at all. the fuses themselves are good, but there may be some internal wiring issues coming out of the fuse box.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Light Subject
RE: Tail “running” lights.
If your front “running” lights come on the problem is not the headlight switch.
Therefore you have a break in the line from the switch back.
Happy Racing!
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog or “running” lights on in good weather beware. WLow performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime
and the nitwits that need headlights for a little rain
If People Drove Any Slower They’d Be Going BackwardsWhen you see fog or “running” lights on in good weather beware. WLow performance driver ahead.
Car: 1983 z28 and 3000gt twin turbo
Engine: 305 v8
Transmission: auto with b&m shifter
Axle/Gears: i dont know. they're stock
are your gauges stuck all the way up passed the max line? or they just dont move. I have an 83 z28 (FUN CAR TO HAVE) and the temp gauge gets stuck. I have to unscrew the dash sometimes and move the needle back down because it gets stuck behind the paneling. the first time it happened I suspected overheating, but it turns out when it has a bit of trouble starting all my gauges go wild and that one sticks. check that
Car: 1982 z28/rs... haha
Engine: 305(now) 333(soon)
Transmission: 350 3-speed automatic
Axle/Gears: 3.45 limited slip 10 bolt
i got the same issue on my 82 z28. i love the car, its my first car, not to mention its got a new 350 and a 350 tranny in it, but my gauges are all messed up exept for a couple of em, and it sucks not knowing how fast im going haha.
https://www.thirdgen.org/forums/inte...eedo-woes.html
JamesC
where is the speedo cale at?
sorry if im seemin dumb, im new to all this right now
Ghettobird52
Jul 5, 2024 11:18 PM
