Fuel pump problem
Car: 1985 chevy camaro
Engine: 2.8 v6
Transmission: 700r4 w/ corvette servo
Fuel pump problem
my 1985 camaro has been sitting for awhile, recently i went to start it and realized i had no fuel. i dont hear the fuel pump kicking on is there anyway to test fuel pump without dropping the gas tank or can anyone think of other possible reasons for it to not work?
Car: 88 GTA
Transmission: WC T5
Axle/Gears: BW 9-bolt 3.27 posi
Re: Fuel pump problem
Yes, there is a way to jump it on the ALDL connector, or you can jump it at the fuel pump relay. There is a sticky that links you to 1985 and 1986 wiring diagrams... in the articles section on the main page, I believe...
OOPS... just checked there, and the link doesn't work. I recommend buying a repair manual. The diagrams you need should be in there.
Engine: 2.8 v6
do you know which hole i use on the aldl to check or will i mess something up if i use wrong hole
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Prime Time
There is a Fuel Pump Prime Connector for testing the pump.
It’s located near the right rear of the engine compartment.
It’s a one wire (18 AWG red wire) connector poking out of the harness.
It’s not plugged in to anything.
Happy Racing!
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog or “running” lights on in good weather beware. WLow performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime
and the nitwits that need headlights for a little rain
If People Drove Any Slower They’d Be Going BackwardsWhen you see fog or “running” lights on in good weather beware. WLow performance driver ahead.
92camaroJoe
Aug 13, 2015 06:07 AM
