Hatch motor Q's.
Old Mar 8, 2010 | 08:02 PM
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Hatch motor Q's.
So today when getting rid of the rust on the Camaro. I decided to see why the hatch wont open via switch and with closer inspection I saw that it wasn't even connected. The only connections on the motor itself was 2 entrys which are right on top of the solenoid. The next weird thing is. the only 2 cables there (Can it be under the carpet? Doubt it but just checking) was 2 cables. 1 which had a metal retainer which seemed to be for the light and the other with 6 connections, 1 red the rest black. After closer checking with a multimeter. The red and 2nd connection on the far corner reads 12v without anything going on. 2 of the 4 of the rest connections matched with the main cable read about 0.30 when the switch of the hatch is pushed.
So whats going on here.
Attached Thumbnails Hatch motor Q's.-cid_601.jpg   Hatch motor Q's.-fap4.jpg   Hatch motor Q's.-cid_412.jpg
Old Mar 9, 2010 | 03:12 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Down The Hatch
The hatch requires power at all times for the Pull-Down function.
That’s the purpose of one of those connectors to be powered at all times.
To learn more you might have to plug those connectors in to see what functions.
However you should know if the Pull-Down unit isn’t functioning properly it might get locked in the up position therefore you won’t be able to close the hatch.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog or “running” lights on in good weather beware. WLow performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime and the nitwits that need headlights for a little rain
Old Mar 9, 2010 | 08:53 PM
Carlos773's Avatar
Re: Down The Hatch
Thats the thing, if you look at the picture, none of those 2 connectors match the connection I saw on the motor. Unless the real connection is some where else. The cable is not there. The cable I tested is in the 3rd picture witch seemed to be the hatch connector with some testing with a multimeter.
The 2nd connector as I showed in the picture seemed to be the light bulb power source for trunk lighting.
So was the hatch motor replaced with another one or or something missing here?
Old Mar 10, 2010 | 11:30 AM
NINÅ's Avatar
Transmission: 765R4
Down The Hatch
There should be one type of hatch motor, altho some are plastic replacing some metal parts.
Plug in (or just eyeball them to prevent it from getting locked in the up position) the connectors.
Now which socket(s) don’t you have a plug for?
Count the number of pins in each unfilled socket to identify the socket.
Happy Racing!
How bout those too scared to drive without headlights in the daytime and the ones that need headlights for a little rain
Old Mar 10, 2010 | 12:06 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Re: Hatch motor Q's.
Someone posted an image of the wiring a while back. You may find it if you search using my screen name.
Edit: Here's some links:
http://www.austinthirdgen.org/mkport...wn_release.jpg
https://www.thirdgen.org/forums/post...08-post21.html
They are found here:
https://www.thirdgen.org/forums/inte...-identify.html
More:
https://www.thirdgen.org/forums/sear...archid=2582457
Old Mar 10, 2010 | 12:35 PM
Carlos773's Avatar
My motor looks way different. Only connector I saw was the one in the pic I provided which had 2 entry points.
I am very confused
Old Mar 10, 2010 | 03:09 PM
Scorpner's Avatar
Engine: V6, V8
Oh, sorry. They changed the motor assemblies and you must have the later style. I was in a hurry and didn't look at your profile. Disregard the info then.
zayne0
Aug 24, 2015 07:22 PM
neekolzun
Aug 24, 2015 04:59 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
1nastygta
Aug 8, 2015 07:38 PM
