Secondary fan switch getting hot
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
I have a toggle switch hooked up to my secondary fan and i've noticed that its getting warm, sometimes hot to touch. its a 3 wire toggle switch but i have the fan ground wire hooked up in the engine bay. So i only have the hot fan wire and the source wire from the fuse box. I also found out that if i hook the hot on one side of the fuse it will blow it but it wont on the battery side of the fuse. Its a 15 amp fuse and the fan is supposed to draw only 12 amps. I used 14G wire so i thought it would be fine. Any help would be appreciated guys.. thanks
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Switch To The Cool Side
That’s because it’s not going to a relay.
Rewire the setup so it turns on the fan relay, not the fan directly.
Happy Racing!
Happy Racing!
Make Noise, Turn Left, Repeat
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
Re: Switch To The Cool Side
Why would a relay matter? It still has to get power from somewhere and the switch is a 20amp
Transmission: 765R4
switch is a 20amp
Happy Racing!
How bout those too scared to drive without headlights in the daytime
and the ones that need headlights for a little rain
Axle/Gears: 9-bolt/3.45
Re: Secondary fan switch getting hot
All you should work with is the fan switch's single green wire(ground wire)... no hot wires and no relays, as those are already connected. So if you're working with the hot wire, then, in effect, it's probably like having connected the power twice, thereby overloading the circuit.
Near the fan switch, splice a wire into the switch's single green wire; run the new wire into the car and connect it to one side of a two-prong toggle switch; wire the other prong to the metal dash frame... done. Flipping the switch completes the ground, turning on the fan.
It's that simple--really.
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
toggle switches are suppose to trigger a relay, not supply the power an accessory requires to function...
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
The hot wire coming off the fan goes to the toggle switch which receives its power from a wire coming from the fuse box to the toggle switch, its not getting power twice.
Transmission: 765R4
Switch Fix
The hot wire coming off the fan goes to the toggle switch which receives its power from a wire coming from the fuse box to the toggle switch………
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
TA8487
Aug 16, 2015 12:21 PM
