Gauges Not Working...
Old Mar 12, 2010 | 10:42 AM
Stavie87IROC's Avatar
Car: 84 T/A
Engine: 400
Transmission: Turbo 350
Ok so only my Volts & Fuel gauge work. My speedo doesn't move at all. My tach looks like it wants to work. When I'm starting my car it jumps from 0-2000+ RPM then once the car is started it drops to 0. I tried to do a search to find out how I could fix it but to no avail. I have an MSD RTR Pro-Billet distributor & Blaster II Coil. I read in a thread somewhere on hear that if you connect the tach wire to the negative side of the coil (12v from ignition on positive) that the tach would read. I did that & nothing. Any ideas on how to fix this problem?
Old Mar 12, 2010 | 11:02 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Gauges Not Working...
It almost sounds as if the cluster were removed at some point and it's never been reseated properly. I'm not a TA guy, but I believe your speedo should be cable-driven. If so, the cable wasn't reconnected at the speedo head or transmission or it's broken somewhere between.
JamesC
Old Mar 12, 2010 | 11:47 AM
Car: 84 T/A
Engine: 400
JamesC
Idk if the dash has been pulled out by the previous owner or not. As far as the speedo goes it's not screwed into the side of the tranny, it's kinda just pushed in place. I'll have to get under the car & check it again.
Old Mar 12, 2010 | 11:52 AM
JamesC's Avatar
Should have a retainer and a single bolt holding it in place. If the drive and driven gear in the trans aren't making contact, the speedo head won't read.
JamesC
Old Mar 12, 2010 | 04:41 PM
johnnymotz27's Avatar
Car: '89 L98 G92 Iroc /'11 GS Vett
Engine: L98/LS3
Transmission: 700R4/M6
Axle/Gears: 3.27 B.W./3.42
I am also having the tach problem on my 88 iroc except mine goes to 7000 after the car is started. Maybe it would help if someone could post a pic of the stock set-up by the coil.
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
