89 GTA Power Window problem
Old Mar 15, 2010 | 02:57 PM
phlipdawg's Avatar
I'm new to the 3rd Gen car. I have recently purchased a 1989 GTA. The windows will not go down, and the heater blower won't come on either. Anyone know if these two circuits are related? Maybe they use the same relay?
Also my headlights won't go up, the lights come on, the motor's spin, but there is no movement.
Old Mar 15, 2010 | 03:49 PM
Steveh4263's Avatar
Car: 1987 Pontiac Trans AM GTA
Engine: 5.7 LTR
Transmission: Automatic
Re: 89 GTA Power Window problem
Could be a blown fuse with the window motor(s) and heater. Not sure about that. But I know what the problem is with the headlight motors. GM put 3 gel bushings in each those motors. They start to crumble and fall apart and then gear has nothing to sit on and they spin. So you will need to replace them with two sets of these http://www.top-downsolutions.com/pro...products_id=35
Old Mar 16, 2010 | 08:41 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Window Of Opportunity
If the AC compressor also won’t come on the problem is the feed going to the fuse block.
The windows have a common circuit amp breaker instead of fuses.
Check the breaker for 12 volts in and out.
If the breaker is OK use a test light or voltmeter to see if you have power at the
pink wire at the switches.
Happy Racing!
If We Don’t Get Cawt We Ain’t Cheatin
Old May 25, 2011 | 03:27 PM
Bolly1965's Avatar
Car: 1989 Trans Am
Engine: 5.0L
I'm in the UK and my power windows failed. I replaced the common circuit amp breaker with a 30 amp fuse and it works fine. I cannot find a supplier of the common circuit amp breaker in the uk - will it be ok to keep using the 30 amp fuse?
Bolly1965's Avatar
Car: 1989 Trans Am
Engine: 5.0L
also - how can the breakers be reset?
Old May 28, 2011 | 02:32 AM
whitedevilTA's Avatar
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
Technically a 30 amp fuse is the same as using a 30 amp circuit breaker...in either instance, they'll blow if they exceed 30 amps, so you should be fine. And I'm pretty sure that a circuit breaker is supposed to reset automatically once you kill power to it. so if you tried that and your's still didn't work I'm guessing it was the problem.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 13, 2015 12:59 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
