Gauge mystery
Gauge mystery
Looking for help. I have an 84 camaro and after installing a wire to the electric choke, I dont have a tach or the amp gauge. I also get a faint buzz from the buzzer unit. Unplugged the wire to the choke, same thing. Checked all fuses and relays, Bad warning relay ? OR??? I'm lost. Also get the faint buzz when applying the brakes. I am assuming a grounding problem but not sure.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Wuzz A Buzz
One at a time disconnect pins B, D, E, G, at the Audio Alarm Assembly.
When the buzz stops you have found the problem circuit.
To gain access to the Audio Alarm Assembly remove the knee bolster.
You’ll find the Audio Alarm Assembly in the ‘Convenience Center’, which is to the right of the steering column.
Happy Racing!
Happy Racing!
How bout those too scared to drive without headlights in the daytime
and the ones that need headlights for a little rain
