Bright lights not working need help quick
Old Mar 19, 2010 | 11:28 PM
82chevyz284bbl's Avatar
Car: 1982 Chevrolet Camaro Z28
Engine: LG4
Transmission: TH350
hey i gotta 82 z28 and my brights just stop workin now the steering colum switch still work just what happends s headlights work but when i click the switch for brights both headlights stop working the fuse is good and wiring i did test the light sockets and they aint gettin a signal anyone have any ideas i need to fixem quick cuz my state inspection goes out this month and i use my car for my job so i got like a week to do it thnx for any help u could give and maybe pics of what ur talkin about if u can
Old Mar 20, 2010 | 06:42 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Bright lights not working need help quick
Headlights
Circuit Operation:
Voltage is applied to the light switch at all times. The light switch includes a self-resetting circuit breaker which opens and closes if the headlight circuit draws too much current. When the light switch is in "Head," the headlight dimmer switch directs current to either the lo beams or the hi beams. Current to the hi beams also flows to the high beam indicator.
Troubleshooting Hints:
If only one headlight doesn't work in both "hi" and "lo", check the ground wiring.
If headlights don't work in just "hi" or just "lo", check headlight dimmer switch.
If headlights flash on and off with switch in "head," isolate short to ground. Operate the headlight dimmer switch to find if the short to ground is in tan or lt grn wires.
If only the "hi'" headlights flash on and off, check lt grn wires for shorts to ground.
If only the "lo" headlights flash on and off, check tan wires for shorts to ground.
If both "hi" and "lo" headlights flash on and off, check the yel wire for a short to ground.
JamesC
Old Mar 20, 2010 | 12:31 PM
Engine: LG4
Transmission: TH350
ok thnxs i think i kinda understand ill see if any of those things u mentioned will help
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
justin57
Aug 20, 2015 07:05 PM
stalkier
Aug 13, 2015 12:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
