odometer inop
Old Mar 21, 2010 | 08:18 AM
Mike McArthur's Avatar
odometer inop
The analog odometer on my 87 GTA does not work but the speedo works fine. It's an L98 car if that matters. The car also only has 51,000 miles on it. Everything else in the car works fine. Any ideas before I start taking it apart?
Old Mar 21, 2010 | 12:23 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: odometer inop
check to see if the sender wires are plugged in on the trans first.
if you have an extra guage pod laying around, swap it in and see what happens. Could be a burnt out motor in the odo assembly, or a broken wire, short, ect ect.
Old Mar 21, 2010 | 02:18 PM
Re: odometer inop
Thanks, I'll give it a try.
Old Mar 24, 2010 | 01:43 PM
Re: odometer inop
I removed the cluster today. Nothing is obviously wrong or broken. Any one know how to fix this thing? This is the electric odometer driven by a small motor.
Old Mar 25, 2010 | 01:54 PM
Re: odometer inop
I found a company called Southern Autotronics in Richmond, VA that knows about these clusters. They said it will cost between $150 and $205 depending on the problem.
http://www.instrumentclusters.com
Old Mar 25, 2010 | 10:48 PM
matts86cam's Avatar
Car: 1986 chevy camaro z28 coupe
Engine: crate 355
Transmission: 700r
Re: odometer inop
Same problem here
where do the wires come out of the tranny at? can you see them from underneath?
Old Mar 26, 2010 | 08:36 AM
Re: odometer inop
If the speedo works and just the odometer is inop, the speed sensor is ok.
PestilenceIV
Sep 22, 2015 07:39 PM
formula1LE
Sep 12, 2015 08:31 PM
andy74
Sep 3, 2015 08:41 AM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
kyle5647
Aug 7, 2015 03:08 PM
