How did you get to the starter/ignition cables?
Old Mar 21, 2010 | 04:29 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
I was attempting to install a remote starter in my 86 trans am tpi 305
i unbolted the 2 13mm nuts and lowered the steering columb.
i was able to unplug the black and blue connectors
but even with the steering lowered as far as it would go I still had very little room and very little slack and i did not have enoguh room to work and splice into the starter/12v/accessory/ignition wires.
what did you guys do?
also when i lowered the steering columb i heard a cracking sound. i looked in the engine bay and theres like a brittle plastic/rubber boot that cracked thats part of holding either oil or grease in the steering columb. its jsut after the bolt holding the steering columb to the bar that goes to the gear box.
is this a problem or what? idk if i can even replace that boot anymore.
Old Mar 21, 2010 | 04:33 PM
Gregzz4's Avatar
Car: '78 GMC Sierra Heavy 1/2
Engine: GMPP ZZ4 Q-Jet
Transmission: 700R4 Stage 2 w/Race Internals
Axle/Gears: 10 Bolt 3:42 Eaton
Re: How did you get to the starter/ignition cables?
Do you want your remote starter for working on the engine?
Why don't you tap into the harness under the hood?
Did that with mine and tapped into the purple wire, but that's my truck
I also added a kill switch under the hood. Tapped into the Bat+ to the Dizzy
Old Mar 21, 2010 | 04:38 PM
Bobby_80s's Avatar
Axle/Gears: no idea
only because everything is right there at that single connector instead of having wires go all over the place.
stretch to battery. then down and under to the starter. then i dont even know where the accessory and ignition wires are.....
but whatever i dont need to have a remote starter it was just part of the alarm system i have and was just trying to do it all.
Old Mar 21, 2010 | 04:43 PM
Gregzz4's Avatar
Ah, an alarm hookup
You led me to believe you were installing a remote starter
What you are doing is correct to hook up the starter kill for your alarm
Old Mar 21, 2010 | 04:45 PM
Bobby_80s's Avatar
Axle/Gears: no idea
its both. and im not installign the kill start.
its both alarm and remote starter.
nevermind.
im more concerned about my steering columb that cracked boot thing.
Old Mar 21, 2010 | 05:36 PM
Bobby_80s's Avatar
Axle/Gears: no idea
so anybody else have same problem?
also im stil trying to find out if i need to worry about that steering shaft boot that cracked....... its just after the connecting bolt in the engine bay between the shaft and interior steering columb. its eithwer a rubber or plastic boot that is hard and cracked.
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
