Ignition buzzer/sound
Old Mar 23, 2010 | 10:44 AM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
I'm not sure what to call the sound.. Its the warning sound the car makes when you turn the ignition to "on" before you start it. I'm assuming this is supposed to be a steady, solid sound. On my car the sound is a little broken up, not steady or smooth sounding. I'm guessing there's a worn electrical contact or switch somewhere, but I'm not sure where to start. I found a key buzzer switch on eckler's camaro, but it was for non-tilt steering up to '89. Mine is a '90 with tilt. Anyone know how to fix this?
Old Mar 23, 2010 | 12:56 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Ignition buzzer/sound
The buzzer itself is located up under the dash on the driver's side. Its plugged into a small fusebox type thing on the side of the center console. The hazard and turn flashers are there too. Its a black box about 2"x3"x1" thick. Try pulling it out and plugging it back in. I tore mine out a while ago cause I was working under the dash with the door open and it was annoying me and I never put it back in.
Old Mar 24, 2010 | 06:40 PM
Pocket's Avatar
Car: 91 Trans Am
I did the same
Its a separate fuseblock thingy. Firebirds locate the headlight door fuses there as well
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
94ElBanditoDeCa
Aftermarket Product Review
Sep 23, 2015 09:05 PM
RedLeader289
Sep 23, 2015 06:50 AM
