Adding electric fan, 1982 TA CFI stock
Old Mar 25, 2010 | 10:20 AM
dsterling@roche's Avatar
Car: 1982 Trans Am, 1997 Grand Prix
Engine: Orig 305 Crossfire FI 36,500 miles
Transmission: original 200c THM
Axle/Gears: original 3.23 posi
Is it possible to add an aftermarket single fan to a 1982 Crossfire FI engine and remove the clutch fan?
I would also update my alternator from the original to a 100 or 140 amp. Could my original wire harness be safely used not over burdening it? I would buy a fan harness that turns on at 180 and shut off at 170.
I am some what electrically challanged. Thanks in advance, David
Old Mar 25, 2010 | 10:26 AM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: Adding electric fan, 1982 TA CFI stock
If your clutch is non electrical, then yeah you shouldn't have a problem, you might have to use a different pulley... so if your fan is not controlled in any way by your ECM, then you shouldn't have a problem... on the alternator, make sure that it's not worn or falling apart, but I would actually recommend that you upgrade your cables anyway... the positive, negative, engine ground... just to be on the safe side...
Old Mar 25, 2010 | 01:20 PM
Pocket's Avatar
Car: 91 Trans Am
A thermal switch controlled electric fan is simple. Buying a kit should be all you need. Hookups should be 12v battery, ground and plugging the thermal switch in. Some more in depth kits have a separate 12v IGN wire to prevent the fan from staying on once the engine is shut down
Both styles are completely self sufficient
Old Mar 25, 2010 | 04:23 PM
KNBlazer This info is a great help! Thanks for your time.....
Old Mar 25, 2010 | 04:26 PM
Pocket Excellent info, very useful. Thanks for all your input.
RazorN8
Jan 7, 2022 11:44 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
mizz0313
Aug 12, 2015 06:45 AM
Leggman1
Aug 6, 2015 04:15 AM
