brake combination valve wiring
Old Mar 26, 2010 | 03:28 PM
williams160's Avatar
Car: 86 camaro
Engine: strong 350
Transmission: stage3 700r4
i have the one wire coming off the combo valve and i have no clue were it goes. i have a aftermarket wiring harness, if someone could help me that would be sweet
Old Mar 26, 2010 | 03:31 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: brake combination valve wiring
I assume to the warning light in the gauge cluster. You may be able to find more info in the following link:
http://www.austinthirdgen.org/index.php?pid=19
JamesC
Old Mar 26, 2010 | 05:19 PM
Car: 86 camaro
Engine: strong 350
they had some other stuff i needed but the did not have that one wire that is coming off the valve. if you hear anything else let me know thank you
Old Mar 26, 2010 | 06:22 PM
JamesC's Avatar
Brake light pressure switch (tan wire):
http://www.austinthirdgen.org/mkport..._continued.gif
JamesC
Old Mar 26, 2010 | 07:40 PM
Car: 86 camaro
Engine: strong 350
lol i must have looked right over it thank you and all it looks to be is a temp warning. do you know by any chance if it needs to be hooked up i do not have any stock gauges.
Old Mar 26, 2010 | 09:03 PM
JamesC's Avatar
If you peruse a bit lower, you'll see that it's the differential brake switch, which essentially warns of failure in the system by way of a dash light. I'd want it operational in my car, but....
JamesC
Old Mar 26, 2010 | 09:32 PM
Car: 86 camaro
Engine: strong 350
ok i see i will see if i can put a light in my dash cuz i have a custom made dash but that is what i was looking in it is needed or not thank you
1992 Trans Am
May 10, 2023 07:19 PM
stalkier
Aug 13, 2015 12:59 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
