PED? dash wiring.
Old Mar 29, 2010 | 04:39 PM
Kamaros's Avatar
Car: 1990 Camaro RS
Engine: LT1 350 5.7L
Axle/Gears: posi rear end
PED? dash wiring.
okay i have pulled my dash from my 92 and put it into a 90 i also swapped engine harness. anyways i put the dash in hooked up all the matching clips and im left off with like 4 non matching wiring. they all say PED and some number. like PED 16, PED 14 PED 8. anyone know what wires they are and what they go to.
Attached Thumbnails PED? dash wiring.-dash-wiring.jpg   PED? dash wiring.-dash-wiring-3.jpg   PED? dash wiring.-dash-wiring-2.jpg
Old Mar 29, 2010 | 07:53 PM
lkswarlock's Avatar
Car: 91 Camaro
Engine: 5.7 355
Transmission: T-5 Tranny
Axle/Gears: 373
Re: PED? dash wiring.
Hope you found out where it goes, I'm actually going through the same thing but my issue is that there is no power going to the ECM, and I'm trying to hook up a scanner to that little black brick there and the scanner that I have will not pick up anything I've tried the scanner on another 91 camaro and it works fine but on mine it doesn't. I know I'm asking for help to because those plugs are the same ones that aren't connected on my car so if anyone can help I would really appreciate it.
Old Mar 30, 2010 | 03:08 PM
Kamaros's Avatar
Car: 1990 Camaro RS
so i took one good look at the wiring again.. i notice there are 2 wires that says PED 14 they both look like relays of some sort. im thinking the relay fuse or box just came off idk. ive saw something laying around didn't think anything of it a couple days before i put the dash in. i hate when i lose things! still wondering what wires go where, any replies back will be appreciated.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
86IROC112
Nov 7, 2015 06:50 AM
Fanatic1074
Oct 2, 2015 03:47 PM
lewandom
Oct 1, 2015 08:15 AM
Eric-86sc
Sep 28, 2015 11:37 AM
