What Distributor do I have?
Old Apr 3, 2010 | 02:55 AM
84CraZ28's Avatar
I have an 84 z28 that has the L69 H.O. engine. I am trying to figure out what distributor I have? Any help is much appreciated
Old Apr 3, 2010 | 02:32 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: What Distributor do I have?
You have a computer controlled HEI distributor. Not replaceable by any off the shelf vacuum-advanced HEI distributor, since the computer controls the timing advance/retard (unless you get rid of the ECM & swap to a non-computer controlled carb - then you'll HAVE to use a vacuum-advanced HEI distributor.
Old Apr 9, 2010 | 06:27 PM
84CraZ28's Avatar
thanks for the reply i'm confused though. so what your telling me is that no one makes or sells any aftermarket dizzy that is a direct replacement that hooks up the same way as the old one?
Old Apr 9, 2010 | 06:44 PM
Car: 1992 RS
Engine: Carbed 350
If it's a computer controlled carb motor, then you'll have to get a computer controlled dist. I'm just saying that a standard aftermarkey HEI with the vacuum advance wouldn't replace a computer controlled dist. I'm sure there would be replacements.
Like the first one here:
http://www.autozone.com/autozone/cat...&parentId=62-0
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
Damon
Sep 26, 2015 04:29 PM
