Pinout for 1987 washer pump connector
Old Apr 4, 2010 | 07:35 PM
89mulletbird's Avatar
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
I'm converting my washer pump from the firewall to a newer style pump in the washer tank. There are 4 wires going to the original washer pump assembly. Which two do I splice into to go to the new pump? Anyone have access to 86-87 wiring diagram for this? I just spent an hour searching the boards and came up empty.
Old Apr 5, 2010 | 01:41 PM
Car: 89 GTA
Axle/Gears: 4.10
Re: Pinout for 1987 washer pump connector
ttt, just need to know where to splice the blue and red wires in from the new pump
Old Apr 6, 2010 | 12:21 PM
Dr.NickRiviera's Avatar
Car: 1987 Trans Am
Engine: tree-fiddy
I just replaced my washer pump and opened the housing it is in and the harness that goes into the unit connects to acircuit bord and that supplies power to the pump. You'd have to trace through that mess.
I'm curious as to why you are going to in tank pump as the replacement pump is like $15 and you'll have to run more wires in the engine bay.
Old Apr 6, 2010 | 02:45 PM
Car: 89 GTA
Axle/Gears: 4.10
I didn't know you could remove the pump from the firewall assembly and replace it. I thought you had to replace the whole assembly and it was almost $100. Oh well, I just hollowed out the old motor and soldered the wires to the motor connectors to run to the new pump.
Infested
May 22, 2018 11:56 PM
beachrodder
Aug 25, 2015 08:05 AM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
g.l.mos
Aug 22, 2015 12:02 AM
Dialed_In
Aug 20, 2015 01:45 PM
