did I break something?
Old Apr 5, 2010 | 01:15 PM
westman's Avatar
Car: 90 Camaro RS
Engine: 6.3L 383 V8
So today I was working on my headlight dimmer switch. My high beams wouldn't come on when I'd pull on the turn signal switch. Dropped the steering column and loosed the screws to move the switch up. Once the switch was all the way up I bolted the steering column back up. Now I have absolutely no tension in the turn signal. It freely flops back and forth. I dropped the column back down and moved the rod back and forth. I noticed right in front of the turn signal, it bulges out when I pull on the rod. Did I break something?
Old Apr 5, 2010 | 02:20 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: did I break something?
sounds like you adjusted it too far - it just needs to be adjust a tad. no need to drop the column - just take the hush panel off the botom and adjust while working the lever until you get it just right.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
apie2546
Oct 16, 2016 02:24 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
sjorgens
Oct 1, 2015 07:54 PM
mfp189
Sep 27, 2015 09:25 AM
