HEI Module Thermal Compound
Old Apr 6, 2010 | 09:06 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
I need to get ahold of some of this stuff. Doesn't seem to be sold unless you by a new module which I don't need.
Will a thermal compound designed for computer use work?
Something like this...http://cgi.ebay.com/Thermal-Grease-P...item5ad7bbab1e
Old Apr 6, 2010 | 10:35 PM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Re: HEI Module Thermal Compound
Hello CamarosRUS!!
IIRC, it's just some silicon dielectric grease available at all automotive stores!!
Buy a tube of it, and use it anywhere you have an electrical connection that you want to protect from water, stray voltage , etc!!
EG: Spark plug boots, (helps for later removal)
Ignition modules, (helps to insulate it, etc (use lots)
Bulb sockets, (helps to keep out water, and prevents corrosion)
At least go look at a tube of it, and read the info on the tube!!!
Old Apr 16, 2010 | 11:33 PM
Mitch91Z28's Avatar
Car: 1991 Vert Z28
Engine: 305... LS1 waiting to drop in
Transmission: 700-R4... soon 4L60E
Axle/Gears: 3.08 posi nine bolt
its actually a thermal compound designed to help transfer heat. dielectric grease is not the same stuff...
Old Apr 17, 2010 | 01:59 AM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
pretty sure dielectric grease is an insulator and impedes voltage.
Old Apr 17, 2010 | 07:19 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
You are correct in the fact dielectric grease acts to insulate but is NOT the same substance as a true thermal compound and does not insulate heat nearly as well.
It seems to stay "wet" longer than most thermal compounds but I will not use it on my module, especially when CPU designed thermal compounds can be found very affordable on eBay or even at Radio Shack.
Old Apr 17, 2010 | 02:59 PM
Hello CamarosRUS!!
Just as a precaution, before you go putting something that's "not" recommended on your ignition module, you might just want to check with the seller of your ignition module, to see if it's returnable after you do so, even if it doesn't work!!
It may end up being a bit expensive to not be able to return something because something was used on it, that "wasn't" recommended!!
P.S. The stuff that you may use may be the cat's meow, but if it's not the "proper" stuff, you haven't got a leg to stand on then!!
Old Apr 20, 2010 | 05:52 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Originally Posted by 87IROC-DAN61
Hello CamarosRUS!!
You are correct, sir, that's why I would never use the dielectric grease. The white thermal compound is where its at and is the stuff that aftermarket modules come with
Old Apr 20, 2010 | 08:06 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Hey I'm with you. I got a little tube of heat sink compound at Radio Shack that works great and is more like the greenish stuff GM used to use on everything. Its made specifically for thermal transfer of heat in electronic parts . Thats exactly what the module is and what it needs
Old Apr 21, 2010 | 12:16 AM
Hello CamarosRUS!!
I'll keep that in mind, if/when I need to replace my ignition module!!
InfernalVortex
Apr 20, 2021 11:31 AM
skinny z
Oct 5, 2015 06:23 PM
dusterbd
Sep 29, 2015 08:40 AM
tattmann
Sep 27, 2015 05:20 PM
Damon
Sep 26, 2015 04:29 PM
