Should be simple... Pics inside!
Old Apr 11, 2010 | 03:48 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Engine: 5.7L TPI> 6.2L
Transmission: 700R-4
Anybody know what the weather pac / 3 wire loom above the rear axle is for???
It's on the rear half of the axle hump towards the bumper... It's not for the fuel pump... I'm thinking rear tail lights....?
I have one wire that stripped/pinched in 2 spots... (don't ask me how or why because its too high to get pinched???)
But I guess I'll be fixing it before I put my torque arm in.......
Any insight would be appreciated..... Thanks!
Old Apr 11, 2010 | 05:36 PM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Re: Should be simple... Pics inside!
Hello GTA Sammy!!
My take on that connector, is that it's connector 313 for the fuel pump, as all the rear lighting electrical comes through the drivers side internally!!
Connector 313 shows only one tan wire for the fuel pump in the schematic, but the connector face drawing shows 3 cavities, 3 cavities means three wires!!
One for pump power, one for the gauge, one for ground????
last time I remember being under the car at that spot, that was the connector that I was undoing for the fuel pump!!
Correct me if I'm wrong!!!
Old Apr 11, 2010 | 05:45 PM
Twin_Turbo's Avatar
That's the connector for the fuel pump/sending unit. Combines fuel pump & fuel level signal
Old Apr 11, 2010 | 05:58 PM
Hello Twin_Turbo!!
That's what I thought that I was trying to say!!
Sort of!!!
Old Apr 11, 2010 | 06:04 PM
Twin_Turbo's Avatar
I know, was just confirming your post BTW, nice to see the "toothpick" still in place. usually those are gone whenever someone (mechanic) disconnects the connector and throws it away
Old Apr 11, 2010 | 09:59 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Thanks gents........hmmmm I'll have to take another look....
I've never had trouble with my fuel pump or sending unit, but if you're right I guess I've been lucky!!!
I was hoping that it would be for my tail-lights as I keep blowing fuses for my brake lights (even though my running lights stay lit....)
I hate electrical problems!!!!!! grrrr Thought that I had figured one out!!!!
Old Apr 12, 2010 | 03:32 AM
Twin_Turbo's Avatar
The harness for the lights runs inside the car along the drivers side.
Old Apr 12, 2010 | 07:29 PM
Hello Twin_Turbo!!
That's what I said in my post!!
Check it out!!
Old Apr 13, 2010 | 01:34 AM
Twin_Turbo's Avatar
I didn't read your post too well dunno why, maybe the smilies put me off subconsciously or something anyhoo kudos go to 87IROC-DAN61
Old Apr 13, 2010 | 02:21 AM
Hello Twin_Turbo!!
I needed some kudos!!!
Hotrodboba400
Dec 10, 2019 07:07 PM
Lanz06
Mar 13, 2019 06:07 PM
mud runner
Nov 2, 2015 07:30 PM
64Chief
Sep 12, 2015 08:05 AM
gt4373
Sep 9, 2015 10:29 AM
